The URL `unreal-engine/required-unreal-engine-plugins/setting-up-the-plugin/lightact-runtime-actor` does not exist. This page may have been moved, renamed, or deleted.
- [LightAct Runtime Actor](https://docs.lightact.com/real-time-content-playback/unreal-engine-integration-overview/required-unreal-engine-plugins/setting-up-the-plugin/lightact-runtime-actor.md)
- [LightAct Timecode](https://docs.lightact.com/real-time-content-playback/unreal-engine-integration-overview/required-unreal-engine-plugins/setting-up-the-plugin/lightact-timecode.md)
- [LightAct Custom Time Step](https://docs.lightact.com/real-time-content-playback/unreal-engine-integration-overview/required-unreal-engine-plugins/setting-up-the-plugin/lightact-custom-time-step.md)
- [Setting up the Plugin](https://docs.lightact.com/real-time-content-playback/unreal-engine-integration-overview/required-unreal-engine-plugins/setting-up-the-plugin.md)
- [Installing LightAct Plugin](https://docs.lightact.com/real-time-content-playback/unreal-engine-integration-overview/required-unreal-engine-plugins/installing-lightact-plugin.md)
GET https://docs.lightact.com/real-time-content-playback/unreal-engine-integration-overview/required-unreal-engine-plugins/setting-up-the-plugin/lightact-runtime-actor.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/real-time-content-playback/unreal-engine-integration-overview/required-unreal-engine-plugins/setting-up-the-plugin/lightact-runtime-actor.md`).
