The URL `understanding-the-basics/how-to-map-content/using-nodes-to-set-content` does not exist. This page may have been moved, renamed, or deleted.
- [Node Connections](https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/node-connections.md)
- [Content Sequencing](https://docs.lightact.com/transitioning-to-lightact-from-other-media-servers/lightact-for-disguise-operators/content-sequencing.md)
- [Deltacast Setup](https://docs.lightact.com/integrations/content-io/deltacast-setup.md)
- [Go to Section](https://docs.lightact.com/layers-and-layouts/stock-layer-templates/control-layer-templates/go-to-section.md)
- [Node Action Flow](https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/node-action-flow.md)
GET https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/node-connections.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/layers-and-layouts/layer-layouts/nodes/node-connections.md`).
