The URL `understanding-the-basics/working-quickly-in-lightact` does not exist. This page may have been moved, renamed, or deleted.
- [Switching to LightAct](https://docs.lightact.com/transitioning-to-lightact-from-other-media-servers/switching-to-lightact.md)
- [Getting your hardware ready to run LightAct](https://docs.lightact.com/preparing-your-hardware-for-lightact/getting-your-hardware-ready-to-run-lightact.md)
- [Asset management in LightNet](https://docs.lightact.com/lightnet/asset-management-in-lightnet.md)
- [EDID Management in LightAct](https://docs.lightact.com/output-setup/output-management/edid-management-in-lightact.md)
- [Testing video playback](https://docs.lightact.com/preparing-your-hardware-for-lightact/testing-video-playback.md)
GET https://docs.lightact.com/transitioning-to-lightact-from-other-media-servers/switching-to-lightact.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/transitioning-to-lightact-from-other-media-servers/switching-to-lightact.md`).
