> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/integrations/content-io.md).
# Content IO
Content provider device nodes are the ones that can receive or send content aka Textures. Among these there are:
* **Video in/out**: these are
  * *Deltacast*
  * *BlackMagic*
  * *DirectShow* compatible sources
* **NDI**
* **Spout**
* **Unreal Texture Share**
All of the above are described in detail in the following pages, except Unreal Texture Share which is described in [Unreal Engine pages](/real-time-content-playback/unreal-engine-integration-overview.md).
## Receiving Content
As usual the process starts in the Devices window.
### Create Receiver Device Nodes
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-e1de7de9f9a5dd8981b13698ff1b117b11dbe7e1%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
The initial setup for receiving Content (a Texture) into LightAct always starts in the **Devices** window where you have to create an appropriate **Receiver** device.
### Getting Content into Layer Layouts
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-dd0d629d3515c51358a2463e4f77a20a4b666cff%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
To get the texture into LightAct's layer system you will always use the same node. It's called **Get Texture (from Device)**.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-936c805505ce7059e84e62aed5101fa534ea643f%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
You can find it by typing in get texture device or similar search keywords.
**Good to know**: in most cases you will be using [Content Input layer template ](/layers-and-layouts/stock-layer-templates/content-layer-templates/content-input-template.md)to get the content into LightAct's layer system.
## Sending Content
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-3e6dfcd55d6f3ca58192deffb47adcd8263ef059%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
LightAct also allows you to send Texture through Content Sender Device nodes.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-1c44a500bee9aabe366cf2afbd942b4311a31963%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
A Layout node that works with these *Sender* Device nodes is called **Set Texture (to Device)**.
**Good to know**: a Stock Layer Template that will give you a head start is called [Send texture](/layers-and-layouts/stock-layer-templates/generative-layer-templates/send-texture.md).
## Special Cases
Some content inputs are slightly different, so you'll find additional information below.
### Deltacast
Please note, LightAct does not support receiving or sending Interlaced video streams.
Deltacast requires a special handling of its FLEX technology. Read more about it:
{% content-ref url="/pages/frufcyhXhma3aqfpdpPk" %}
[Deltacast FLEX Management](/integrations/content-io/deltacast-setup/flex-management.md)
{% endcontent-ref %}
### RealSense
RealSense is primarily designed for computer vision so there is a slightly different approach.
{% content-ref url="/pages/1XDWWpDJsAexKTE4L0ux" %}
[RealSense](/integrations/content-io/realsense.md)
