Send Texture
Category: Generative
Send Texture is one of the a layer template that you can use to send a texture through one of texture sender devices in the Devices window. One possible use is to stream a texture through NDI.
Variables
Send texture
Device: select the device you'd would like to stream the texture through. An example is NDI or Spout.
Texture: the texture you want to stream.
Setting up
This layer template relies on Layer Connections. This means that the Texture variable needs to be the destination of another Source layer.
