Texture Softedge node
You can access Blend feature alone through Texture Softedge node.
Drag the Texture output pin of your chosen media file and select Texture Softedge from the Search menu.
Click on Setup to open the dedicated window.
Softedge
In Softedge setup window, you can add soft-edges to your texture. Similarly to Softedge feature in the Warp & Blend node, drag the handles inwards to see the effect.
By adjusting the Luminance, you can adjust the color of the soft edges. Each Luminance variable represents one RGB channel.
