The URL `dmx/dmx-setup` does not exist. This page may have been moved, renamed, or deleted.
- [Sending DMX](https://docs.lightact.com/dmx/dmx-out.md)
- [Receiving DMX](https://docs.lightact.com/dmx/dmx-in.md)
- [DMX Overview](https://docs.lightact.com/dmx/dmx-overview.md)
- [DMX by UV](https://docs.lightact.com/dmx/dmx-out/dmx-by-uv.md)
- [Fixture Editor](https://docs.lightact.com/dmx/dmx-out/fixture-editor.md)
GET https://docs.lightact.com/dmx/dmx-out.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/dmx/dmx-out.md`).
