> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/layers-and-layouts/stock-layer-templates/generative-layer-templates/texture-to-mapping.md). Agents can also search and read this documentation through its [MCP server](https://docs.lightact.com/~gitbook/mcp).
# Texture to Mapping
Category: Generative
**Texture to mapping** is one of the generative layer templates that simply renders an incoming texture to a maping you select. It is useful if you want to render one texture to several different mappings.
### **Render**
Explained in [Stock Layer Templates](https://docs.lightact.com/layers-and-layouts/stock-layer-templates.md) with 2 additional variables:
* **Texture**: The texture that is going to be rendered to a mapping. It is also a Destination variable for a Layer connection.
* **Auto rename:** It renames the layer based on the selected Mapping.
## Setting up
This layer template relies on [Layer Connections](https://docs.lightact.com/layers-and-layouts/layer-connections.md). This means that the *Texture* variable needs to be the destination of another *Source* layer.
