LightAct 4 Docs
LightAct WebpagePDF Version
  • LightAct 4 Documentation
  • Understanding the Basics
    • Overview of Content Pipeline
    • Pushing Content out of LightAct
    • Terminology
    • How to map Content
      • Creating a Canvas
      • Creating a Layer
      • Creating a Video Screen
      • Mapping a Canvas to a Video screen
      • Creating a Perspective Thrower
      • Using Nodes to Set Content
      • Mapping to Outputs
    • Working quickly in LightAct
      • Window docking & workspaces
      • Drag & drop
      • Viewport Navigation
    • Launching LightAct with Arguments
    • Top Bar
    • LightAct Performance
  • Transitioning to LightAct from other media servers
    • Switching to LightAct
    • LightAct for Disguise Operators
      • GUI Overview
      • Content Sequencing
      • Content Mapping
    • LightAct for Pixera Operators
  • Content mapping
    • Canvas mapping
    • Throwers
      • Thrower Properties
      • Perspective Thrower
      • Cubic thrower
      • Spherical Thrower
    • 3D model
      • Rendering Mode
      • Multiple materials & sources
      • Preparing 3D Models
        • Organize the 3D Scene
        • Materials in 3D models
        • UV Mapping of 3D Models
      • Outputting 3D Model's Texture
  • TIMELINES
    • Overview
    • Timelines Window
    • Timeline Editor Window
      • Sections
      • Markers
      • Curve Editor
    • Cues
      • Cue List
  • LAYERS AND LAYOUTS
    • Overview
    • Stock Layer Templates
      • Content Layer Templates
        • Video
      • Generative Layer Templates
        • Checkerboard
        • Color grid
        • Gradient
        • Mapping ID
        • Render Time
        • Scroll Texture
        • Send Texture
        • Solid Color
        • Strobe
        • Text
        • Texture to Mapping
      • Control Layer Templates
        • Go to Marker
        • Go to Section
        • Receive message
        • Send DMX
        • Send message
        • Set Fade
        • Set Timeline State
        • Set Volume
    • Layers
      • Layer Properties
      • Layer Layouts
      • Cross-fade
    • User Layer Templates
    • Variables
      • Variable Management
      • Control Variables with DMX, OSC, or Curves
    • Nodes
      • Node Connections
      • Node Action Flow
      • Order of Node Execution
      • Texture Processing
        • LUT
        • Luma Key
        • Rotate
      • Computer Vision
        • Optical Flow
        • Find Blobs
        • Mog2 Background Subtraction
        • Combine
        • Convert CV Color
        • Subtract
  • Node reference
    • Node reference
    • Layout nodes
      • Lifeline and actions node category
        • Tick node
      • Texture generators node category
    • Device nodes
  • Content Playback
    • Video Formats & Codecs
    • Playing Video
    • Playing Image Sequences
    • Images
    • Playing Notch Blocks
    • Projection Study
    • 2D Projection Mapping Workflow
    • 3D Projection Mapping Workflow
    • 3DCal
      • Setting up Iris Device Node
      • Adjusting Focus
      • Adding and calibrating Iris camera
      • Calibrating projectors using Iris
      • IrisVirtual
    • AutoBlend
    • Warp & Blend
      • Texture Warp & Blend node
      • Texture Mesh Warp node
      • Texture Perspective Warp node
      • Texture Softedge node
      • Warp & Blend Output Window
    • Texture Mask
    • DMX Overview
    • DMX Setup
    • DMX Out
      • Fixture Editor
      • Output to DMX Fixture
      • Set DMX in Layer Layouts
    • DMX In
      • Adjust layer variables with DMX
      • Index manager
      • Get DMX in Layer Layouts
      • Control by DMX
    • DMX by UV
    • Unreal Engine Integration Overview
    • Required Unreal Engine Plugins
      • Installing LightAct Plugin
      • Setting up the Plugin
        • LightAct Runtime Actor
        • LightAct Custom Time Step
        • LightAct Timecode
    • UnrealLink
    • Texture Sharing
      • Thrower2UCam
      • Projector2UCam
      • ViewportUCam
  • Integrations
    • Camera and object tracking
      • Camera Tracking
        • Stype
        • Mo-Sys
        • FreeD
        • Ncam
        • SPNet
      • Object Tracking
        • PSN
        • BlackTrax
        • OptiTrack
        • Vive
        • Antilatency
      • Tracking Visualizer
      • Tracking Follower
    • Network
      • TCP & UDP
      • OSC
        • OSCLearn
      • TUIO
    • Serial
      • MIDI
    • Audio
    • Content IO
      • NDI
      • Deltacast
        • FLEX Management
      • ZED
      • RealSense
    • OSCIn
    • 10-Bit Displays
  • LightNet
    • LightNet Overview
    • LightNet Clusters
      • Scan Network
      • Connect to Secondary Machines
      • Transfer and Open Project
      • Cluster Management
    • LightNet Performance
      • Canvas Distribution
      • Layer Distribution
      • Asset Distribution
      • Viewport Object Distribution
      • VRAM Improvements
    • LightSync
  • WebUI
    • WebUI Setup
  • GPU Management
    • EDID Management
      • Export EDID
      • Load EDID
      • Unload EDID
    • Synchronize GPU Outputs
    • Multiple GPUs
      • Mosaic
        • Set up Mosaic
        • Modify or Disable Mosaic
      • Primary Display
      • Workflow
    • DisplayPort - HDMI converters
  • Licensing
    • Licensing Overview
    • Adding or updating a License
    • Applying a License
    • Transferring a License
  • Troubleshooting
    • Iris Troubleshooting
    • Unreal Engine Integration Troubleshooting
      • Texture Sharing Troubleshooting
    • LightNet Troubleshooting
    • Notch Troubleshooting
    • GPU Management Troubleshooting
    • Asking for support
Powered by GitBook
On this page
  1. Projection Mapping
Warp & Blend
Warp & Blend is a very useful feature that allows users to manually warp the texture or apply a Softedge to it.
We can access the Warp & Blend feature in two different ways:
  • Manually through nodes such as Warp & Blend, Softedge, Mesh Warp, Perspective Warp and
  • Video Output window.
PreviousAutoBlendNextTexture Warp & Blend node
Last updated 2 years ago
