The URL `understanding-the-basics/working-quickly-in-lightact/window-docking-and-workspaces` does not exist. This page may have been moved, renamed, or deleted.
- [Drag & drop](https://docs.lightact.com/quick-start/user-interface/drag-and-drop.md)
- [Fade in and Fade out](https://docs.lightact.com/layers-and-layouts/fade-in-and-fade-out.md)
- [Switching to LightAct](https://docs.lightact.com/transitioning-to-lightact-from-other-media-servers/switching-to-lightact.md)
- [Testing your computer](https://docs.lightact.com/preparing-your-hardware-for-lightact/testing-your-computer.md)
- [Testing video playback](https://docs.lightact.com/preparing-your-hardware-for-lightact/testing-video-playback.md)
GET https://docs.lightact.com/quick-start/user-interface/drag-and-drop.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/quick-start/user-interface/drag-and-drop.md`).
