The URL `content-mapping/3d-model/multiple-materials-and-sources` does not exist. This page may have been moved, renamed, or deleted.
- [Content mapping overview](https://docs.lightact.com/content-mapping/content-mapping-overview.md)
- [UV Mapping of 3D Models](https://docs.lightact.com/assets/3d-model/uv-mapping-of-3d-models.md)
- [Canvas Maps](https://docs.lightact.com/content-mapping/canvas-mapping.md)
- [Throwers](https://docs.lightact.com/content-mapping/throwers.md)
- [AutoBlend](https://docs.lightact.com/projection-mapping/3d-projection-mapping-workflow/autoblend.md)
GET https://docs.lightact.com/content-mapping/content-mapping-overview.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/content-mapping/content-mapping-overview.md`).
