The URL `gpu-management/multiple-gpus/primary-display` does not exist. This page may have been moved, renamed, or deleted.
- [Primary Display](https://docs.lightact.com/output-setup/output-management/multiple-gpus/primary-display.md)
- [Workflow](https://docs.lightact.com/output-setup/output-management/multiple-gpus/workflow.md)
- [10-Bit Displays](https://docs.lightact.com/integrations/10-bit-displays.md)
- [Modify or Disable Mosaic](https://docs.lightact.com/output-setup/output-management/modify-or-disable-mosaic.md)
- [Generative Layer Templates](https://docs.lightact.com/layers-and-layouts/stock-layer-templates/generative-layer-templates.md)
GET https://docs.lightact.com/output-setup/output-management/multiple-gpus/primary-display.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/output-setup/output-management/multiple-gpus/primary-display.md`).
