The URL `understanding-the-basics/how-to-map-content/creating-a-perspective-thrower` does not exist. This page may have been moved, renamed, or deleted.
- [Content Layer Templates](https://docs.lightact.com/layers-and-layouts/stock-layer-templates/content-layer-templates.md)
- [Setting up Iris Device Node](https://docs.lightact.com/projection-mapping/iris/setting-up-iris-device-node.md)
- [Testing your computer](https://docs.lightact.com/preparing-your-hardware-for-lightact/testing-your-computer.md)
- [Tracking Visualizer](https://docs.lightact.com/integrations/camera-and-object-tracking/tracking-visualizer.md)
- [Projection Mapping](https://docs.lightact.com/transitioning-to-lightact-from-other-media-servers/lightact-for-disguise-operators/projection-mapping.md)
GET https://docs.lightact.com/layers-and-layouts/stock-layer-templates/content-layer-templates.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/layers-and-layouts/stock-layer-templates/content-layer-templates.md`).
