LightAct 4 Docs
LightAct WebpagePDF Version
  • LightAct 4 Documentation
  • Understanding the Basics
    • Overview of Content Pipeline
    • Pushing Content out of LightAct
    • Terminology
    • How to map Content
      • Creating a Canvas
      • Creating a Layer
      • Creating a Video Screen
      • Mapping a Canvas to a Video screen
      • Creating a Perspective Thrower
      • Using Nodes to Set Content
      • Mapping to Outputs
    • Working quickly in LightAct
      • Window docking & workspaces
      • Drag & drop
      • Viewport Navigation
    • Launching LightAct with Arguments
    • Top Bar
    • LightAct Performance
  • Transitioning to LightAct from other media servers
    • Switching to LightAct
    • LightAct for Disguise Operators
      • GUI Overview
      • Content Sequencing
      • Content Mapping
    • LightAct for Pixera Operators
  • Content mapping
    • Canvas mapping
    • Throwers
      • Thrower Properties
      • Perspective Thrower
      • Cubic thrower
      • Spherical Thrower
    • 3D model
      • Rendering Mode
      • Multiple materials & sources
      • Preparing 3D Models
        • Organize the 3D Scene
        • Materials in 3D models
        • UV Mapping of 3D Models
      • Outputting 3D Model's Texture
  • TIMELINES
    • Overview
    • Timelines Window
    • Timeline Editor Window
      • Sections
      • Markers
      • Curve Editor
    • Cues
      • Cue List
  • LAYERS AND LAYOUTS
    • Overview
    • Stock Layer Templates
      • Content Layer Templates
        • Video
      • Generative Layer Templates
        • Checkerboard
        • Color grid
        • Gradient
        • Mapping ID
        • Render Time
        • Scroll Texture
        • Send Texture
        • Solid Color
        • Strobe
        • Text
        • Texture to Mapping
      • Control Layer Templates
        • Go to Marker
        • Go to Section
        • Receive message
        • Send DMX
        • Send message
        • Set Fade
        • Set Timeline State
        • Set Volume
    • Layers
      • Layer Properties
      • Layer Layouts
      • Cross-fade
    • User Layer Templates
    • Variables
      • Variable Management
      • Control Variables with DMX, OSC, or Curves
    • Nodes
      • Node Connections
      • Node Action Flow
      • Order of Node Execution
      • Texture Processing
        • LUT
        • Luma Key
        • Rotate
      • Computer Vision
        • Optical Flow
        • Find Blobs
        • Mog2 Background Subtraction
        • Combine
        • Convert CV Color
        • Subtract
  • Node reference
    • Node reference
    • Layout nodes
      • Lifeline and actions node category
        • Tick node
      • Texture generators node category
    • Device nodes
  • Content Playback
    • Video Formats & Codecs
    • Playing Video
    • Playing Image Sequences
    • Images
    • Playing Notch Blocks
    • Projection Study
    • 2D Projection Mapping Workflow
    • 3D Projection Mapping Workflow
    • 3DCal
      • Setting up Iris Device Node
      • Adjusting Focus
      • Adding and calibrating Iris camera
      • Calibrating projectors using Iris
      • IrisVirtual
    • AutoBlend
    • Warp & Blend
      • Texture Warp & Blend node
      • Texture Mesh Warp node
      • Texture Perspective Warp node
      • Texture Softedge node
      • Warp & Blend Output Window
    • Texture Mask
    • DMX Overview
    • DMX Setup
    • DMX Out
      • Fixture Editor
      • Output to DMX Fixture
      • Set DMX in Layer Layouts
    • DMX In
      • Adjust layer variables with DMX
      • Index manager
      • Get DMX in Layer Layouts
      • Control by DMX
    • DMX by UV
    • Unreal Engine Integration Overview
    • Required Unreal Engine Plugins
      • Installing LightAct Plugin
      • Setting up the Plugin
        • LightAct Runtime Actor
        • LightAct Custom Time Step
        • LightAct Timecode
    • UnrealLink
    • Texture Sharing
      • Thrower2UCam
      • Projector2UCam
      • ViewportUCam
  • Integrations
    • Camera and object tracking
      • Camera Tracking
        • Stype
        • Mo-Sys
        • FreeD
        • Ncam
        • SPNet
      • Object Tracking
        • PSN
        • BlackTrax
        • OptiTrack
        • Vive
        • Antilatency
      • Tracking Visualizer
      • Tracking Follower
    • Network
      • TCP & UDP
      • OSC
        • OSCLearn
      • TUIO
    • Serial
      • MIDI
    • Audio
    • Content IO
      • NDI
      • Deltacast
        • FLEX Management
      • ZED
      • RealSense
    • OSCIn
    • 10-Bit Displays
  • LightNet
    • LightNet Overview
    • LightNet Clusters
      • Scan Network
      • Connect to Secondary Machines
      • Transfer and Open Project
      • Cluster Management
    • LightNet Performance
      • Canvas Distribution
      • Layer Distribution
      • Asset Distribution
      • Viewport Object Distribution
      • VRAM Improvements
    • LightSync
  • WebUI
    • WebUI Setup
  • GPU Management
    • EDID Management
      • Export EDID
      • Load EDID
      • Unload EDID
    • Synchronize GPU Outputs
    • Multiple GPUs
      • Mosaic
        • Set up Mosaic
        • Modify or Disable Mosaic
      • Primary Display
      • Workflow
    • DisplayPort - HDMI converters
  • Licensing
    • Licensing Overview
    • Adding or updating a License
    • Applying a License
    • Transferring a License
  • Troubleshooting
    • Iris Troubleshooting
    • Unreal Engine Integration Troubleshooting
      • Texture Sharing Troubleshooting
    • LightNet Troubleshooting
    • Notch Troubleshooting
    • GPU Management Troubleshooting
    • Asking for support
Powered by GitBook
On this page
  1. Content mapping
  2. 3D model
PreviousUV Mapping of 3D ModelsNextOverview
Last updated 3 years ago
You can output a texture of a 3D model in the Video Output window. Open a Video Output window (F6) and create a video output.
In this case, I'm outputting a 3D model of a curved wall behind the car to the main display. Connect the appropriate rectangle on the left side of the Video Output window with an output on the right, then click Enable.
You can output the texture of 3D models directly, but only if the 3D model contains only one object. If it contains several sub-objects, it is not possible to output it's texture directly to video outputs.
