The URL `understanding-the-basics/how-to-map-content/creating-a-layer` does not exist. This page may have been moved, renamed, or deleted.
- [Content Layer Templates](https://docs.lightact.com/layers-and-layouts/stock-layer-templates/content-layer-templates.md)
- [Variables](https://docs.lightact.com/layers-and-layouts/layer-layouts/variables.md)
- [Generative Layer Templates](https://docs.lightact.com/layers-and-layouts/stock-layer-templates/generative-layer-templates.md)
- [Tracking Visualizer](https://docs.lightact.com/integrations/camera-and-object-tracking/tracking-visualizer.md)
- [Content input](https://docs.lightact.com/layers-and-layouts/stock-layer-templates/content-layer-templates/content-input-template.md)
GET https://docs.lightact.com/layers-and-layouts/stock-layer-templates/content-layer-templates.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/layers-and-layouts/stock-layer-templates/content-layer-templates.md`).
