The URL `understanding-the-basics/how-to-map-content/mapping-to-outputs` does not exist. This page may have been moved, renamed, or deleted.
- [Content mapping overview](https://docs.lightact.com/content-mapping/content-mapping-overview.md)
- [UV Mapping of 3D Models](https://docs.lightact.com/assets/3d-model/uv-mapping-of-3d-models.md)
- [Switching to LightAct](https://docs.lightact.com/transitioning-to-lightact-from-other-media-servers/switching-to-lightact.md)
- [Mapping by index](https://docs.lightact.com/node-reference/node-reference/layout-nodes/array-operations-node-category/mapping-by-index.md)
- [Multiple GPUs](https://docs.lightact.com/output-setup/output-management/multiple-gpus.md)
GET https://docs.lightact.com/content-mapping/content-mapping-overview.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/content-mapping/content-mapping-overview.md`).
