The URL `projection-mapping/texture-mask` does not exist. This page may have been moved, renamed, or deleted.
- [Projection Mapping](https://docs.lightact.com/projection-mapping/projection-mapping.md)
- [Iris](https://docs.lightact.com/projection-mapping/iris.md)
- [Projection Study](https://docs.lightact.com/projection-mapping/projection-study.md)
- [2D Projection Mapping Workflow](https://docs.lightact.com/projection-mapping/2d-projection-mapping-workflow.md)
- [3D Projection Mapping Workflow](https://docs.lightact.com/projection-mapping/3d-projection-mapping-workflow.md)
GET https://docs.lightact.com/projection-mapping/projection-mapping.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/projection-mapping/projection-mapping.md`).
