> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/dmx/dmx-in/control-by-dmx.md). Agents can also search and read this documentation through its [MCP server](https://docs.lightact.com/~gitbook/mcp).
# Master DMX Control
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-c37dc62106d26abaa01c1a6444df69755af158f1%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
To control software-level properties with DMX, you can use **Control by DMX** window.
To do this, open the **Control by DMX** window which you can find under *Tools* in the *Top Bar,* and enable it. Here you can trigger or control:
* **Master control**: Master Fade and Master Volume
* **Output fades**: Fades of Virtual outputs.
* **Global variables**.
With the **Universe** property, you can assign a Universe within which DMX values will control the above-mentioned properties.
In the *Start channels* section, the difference between two consecutive Start channels determines which Channels are reserved for each property.
By selecting the same **Universe** in the *DMX In* window, you should be able to see all the Channels that you have chosen, appear as green. If you **hover** over these Channels, you will see a tooltip with the property that is being controlled on that Universe and Channel.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-a1394644e29da3806b674b2244fa0a931a9b34da%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
## Controlling Global Variables with DMX
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-dbbc654439b65df6b35fb2785e09e3614db19363%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
To control global variables with DMX you have to set them up the same way as Layer variables. More information how to do that is available in [Controlling Layers with DMX](https://docs.lightact.com/dmx/dmx-in/adjust-layer-variables-with-dmx.md).
