> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/layers-and-layouts/stock-layer-templates/control-layer-templates/set-volume.md).
# Set Volume
Category: Control
**Set volume** layer template changes the audio volume of a section or a layer.
### Default
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-f5d86b03ef6d5bde6cfa383a11578ea4faa87a1d%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
* **Mode**: select the volume of what you'd like to adjust. Options are:
  * *Section Volume*: adjusts the volume of the selected section.
  * *Layer Volume*: adjusts the volume of the selected layer.
* **Master volume**: set the new value of the master volume fade. 1 = 100% (fully on), 0 = 0% (silent).
* **Speed**: adjust the speed of the adjustment. 1 means real-time. If you set it to really small values, like 0.2, the fade value will adjust slowly towards the target value.
* **Auto rename:** select if you want the layer's name to display the state of the variables.
