The URL `gpu-management/synchronize-gpu-outputs` does not exist. This page may have been moved, renamed, or deleted.
- [Sending OSC](https://docs.lightact.com/osc-and-midi/sending-osc.md)
- [Shortcuts](https://docs.lightact.com/quick-start/shortcuts.md)
- [Finding LightAct Machines](https://docs.lightact.com/lightnet/lightnet-clusters.md)
- [Receiving OSC](https://docs.lightact.com/osc-and-midi/receiving-osc.md)
- [Setting up your computer](https://docs.lightact.com/preparing-your-hardware-for-lightact/setting-up-your-computer.md)
GET https://docs.lightact.com/osc-and-midi/sending-osc.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/osc-and-midi/sending-osc.md`).
