The URL `understanding-the-basics/top-bar` does not exist. This page may have been moved, renamed, or deleted.
- [Top Bar](https://docs.lightact.com/quick-start/user-interface/top-bar.md)
- [Cross-fade](https://docs.lightact.com/layers-and-layouts/cross-fade.md)
- [LightNet basics](https://docs.lightact.com/lightnet/lightnet-basics.md)
- [Stock Layer Templates](https://docs.lightact.com/layers-and-layouts/stock-layer-templates.md)
- [User Layer Templates](https://docs.lightact.com/layers-and-layouts/user-layer-templates.md)
GET https://docs.lightact.com/quick-start/user-interface/top-bar.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/quick-start/user-interface/top-bar.md`).
