The URL `video-playback-performance/double-2` does not exist. This page may have been moved, renamed, or deleted.
- [Double 2](https://docs.lightact.com/video-playback/video-playback-performance/double-2.md)
- [Proxy video files](https://docs.lightact.com/video-playback/proxy-video-files.md)
- [LightAct Hardware video playback performance](https://docs.lightact.com/video-playback/video-playback-performance.md)
- [Video playback troubleshooting](https://docs.lightact.com/video-playback/video-playback-troubleshooting.md)
- [Frame buffering](https://docs.lightact.com/video-playback/frame-buffering.md)
GET https://docs.lightact.com/video-playback/video-playback-performance/double-2.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/video-playback/video-playback-performance/double-2.md`).
