The URL `understanding-the-basics/working-quickly-in-lightact/drag-and-drop` does not exist. This page may have been moved, renamed, or deleted.
- [Drag & drop](https://docs.lightact.com/quick-start/user-interface/drag-and-drop.md)
- [TCP & UDP](https://docs.lightact.com/integrations/network/tcp-and-udp.md)
- [Fade in and Fade out](https://docs.lightact.com/layers-and-layouts/fade-in-and-fade-out.md)
- [Deltacast Setup](https://docs.lightact.com/integrations/content-io/deltacast-setup.md)
- [LightAct 4.16.RC1](https://docs.lightact.com/release-changelogs/lightact-4.16/lightact-4.16.rc1.md)
GET https://docs.lightact.com/quick-start/user-interface/drag-and-drop.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/quick-start/user-interface/drag-and-drop.md`).
