The URL `content-playback/playing-video` does not exist. This page may have been moved, renamed, or deleted.
- [Playing video files](https://docs.lightact.com/video-playback/playing-video-files.md)
- [Proxy video files](https://docs.lightact.com/video-playback/proxy-video-files.md)
- [Content mapping overview](https://docs.lightact.com/content-mapping/content-mapping-overview.md)
- [LightAct Hardware video playback performance](https://docs.lightact.com/video-playback/video-playback-performance.md)
- [Video playback troubleshooting](https://docs.lightact.com/video-playback/video-playback-troubleshooting.md)
GET https://docs.lightact.com/video-playback/playing-video-files.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/video-playback/playing-video-files.md`).
