The URL `timelines-layers-and-templates/timelines-window` does not exist. This page may have been moved, renamed, or deleted.
- [Fast layer workflows](https://docs.lightact.com/layers-and-layouts/fast-layer-workflows.md)
- [Overview](https://docs.lightact.com/layers-and-layouts/overview.md)
- [Fade in and Fade out](https://docs.lightact.com/layers-and-layouts/fade-in-and-fade-out.md)
- [Cross-fade](https://docs.lightact.com/layers-and-layouts/cross-fade.md)
- [Curve Editor](https://docs.lightact.com/layers-and-layouts/curve-editor.md)
GET https://docs.lightact.com/layers-and-layouts/fast-layer-workflows.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/layers-and-layouts/fast-layer-workflows.md`).
