The URL `timelines-layers-and-templates/layers-nodes-and-variables/nodes/computer-vision/find-blobs` does not exist. This page may have been moved, renamed, or deleted.
- [Find Blobs](https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/computer-vision/find-blobs.md)
- [Optical Flow](https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/computer-vision/optical-flow.md)
- [Convert CV Color](https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/computer-vision/convert-cv-color.md)
- [Computer Vision](https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/computer-vision.md)
GET https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/computer-vision/find-blobs.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/layers-and-layouts/layer-layouts/nodes/computer-vision/find-blobs.md`).
