The URL `timelines-sequences-layers-and-templates/layers-nodes-and-variables/nodes/computer-vision/mog2-background-subtraction` does not exist. This page may have been moved, renamed, or deleted.
- [Mog2 Background Subtraction](https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/computer-vision/mog2-background-subtraction.md)
- [Subtract](https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/computer-vision/subtract.md)
- [Convert CV Color](https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/computer-vision/convert-cv-color.md)
- [Optical Flow](https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/computer-vision/optical-flow.md)
GET https://docs.lightact.com/layers-and-layouts/layer-layouts/nodes/computer-vision/mog2-background-subtraction.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/layers-and-layouts/layer-layouts/nodes/computer-vision/mog2-background-subtraction.md`).
