The URL `timelines-sequences-layers-and-templates/layers-and-markers/layer-layouts` does not exist. This page may have been moved, renamed, or deleted.
- [Layer Layouts](https://docs.lightact.com/layers-and-layouts/layer-layouts.md)
- [Layer variables](https://docs.lightact.com/layers-and-layouts/layer-layouts/variables/layer-variables.md)
- [Variables](https://docs.lightact.com/layers-and-layouts/layer-layouts/variables.md)
- [Content Layer Templates](https://docs.lightact.com/layers-and-layouts/stock-layer-templates/content-layer-templates.md)
- [Control Layer Templates](https://docs.lightact.com/layers-and-layouts/stock-layer-templates/control-layer-templates.md)
GET https://docs.lightact.com/layers-and-layouts/layer-layouts.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/layers-and-layouts/layer-layouts.md`).
