Channel mixer
Category: Generative
Channel mixer is a layer template that takes 2 textures and mixes their channels in an arbitrary way to create its output texture.
In the image above what's happening is this:
Color grid is rendered to the video screen first. That's just for visualisation of the alpha.
The 2 gradients are feeding their outputs into the Channel mixer layer
Channel mixer layer is mixing (rerouting) their channels to create the texture that is rendered on top of the Color grid.
Variables
Render
Explained in Stock Layer Templates.
Texture channel mixer
Input 1: the first of the two input textures. It needs to come from another layer using Layer connections.
Input 2: the second of the two input textures. It needs to come from another layer using Layer connections.
R source: using the dropdown specify which channel of the 2 input textures will be used for the R channel of the output texture.
G source: using the dropdown specify which channel of the 2 input textures will be used for the G channel of the output texture.
B source: using the dropdown specify which channel of the 2 input textures will be used for the B channel of the output texture.
A source: using the dropdown specify which channel of the 2 input textures will be used for the A channel of the output texture.
