> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/miscellaneous/webui-setup.md).
# WebUI Setup
WebUI feature is available for LightAct **server license** only.
## Overview
WebUI enables you to setup **custom user interface** and **control LightAct** from any device's browser connected to the same network as LightAct.
## Setup
First look up your IP address in **Command Prompt.** Open Command Prompt **as administrator** and type **ipconfig.** Copy your IPv4 adress.
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-bdf3275fe2d5aebcf455fe11f42c6761945bf42d%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure>
Open **http-server.exe** and look up your port number. You can find it under *C:\WebUI 4\dist\http-server.exe*
**Good to know:** If you cannot fine **http-server.exe** file on your server, feel free to contact us at <support@lightact.com>.
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-e710fc1fd51c8084934971e1ecf5e52d47936d33%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure>
Open LightAct, go to Project Settings, and under General, enable **Enable** **REST & WebUI.**
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-f7f62435277126e6c7f89be25fa1d1db913a5543%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure>
Open any web browser and type your **IP** and **Port**, followed by **/index.html,** for example *"192.168.0.111:8000/index.html".*
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-1087ef9dd39f9c5b4d25f4ad8059e9fb9e1f86f4%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure>
If WebUI doesn't receive data, uncheck **Enable REST & WebUI** button and then check it again. Ensure that the device you are trying to access WebUI on is in the same network on which LightAct is running.
You can add custom variables by dragging a **Local variable** to a [**Global variable**](https://docs.lightact.com/layers-and-layouts/variables#global-variables) **group** or by directly adding a **Global variable**.
Make sure to expand the right side window enough to see **WebUI icon**. Click on it to enable the variable in WebUI.
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-fc2cfce918ab8b08f1740eba5e1885dd362b3415%2FWebUI%20Enable%20in%20LightAct.gif?alt=media" alt=""><figcaption></figcaption></figure>
Successful configuration should look something like this.
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-19eaa5f8dce59e30bdb5c6a625154264e7cf69b1%2FWebUI%20Custom%20variable.png?alt=media" alt=""><figcaption></figcaption></figure>
You can also set the **Default value** and **Min and max** value.
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-40cfd4d05852c8b3e87beed0be5bca2555e4b4e6%2FWebUI%20Default%2C%20min%20and%20max%20values.gif?alt=media" alt=""><figcaption></figcaption></figure>
All global variables, that have the **WebUI** button enabled should be visible in WebUI.
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-ab4aea93b2afddb586f9e3da5a72c160485e93c7%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure>
