> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/layers-and-layouts/fast-layer-workflows.md).
# Fast layer workflows
There are many different actions and shortcuts that can make your workflows faster and more efficient. Let's go through them.
## Creating layers
There are several ways to insert a layer.
### With right click menu
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-c61d6d77d50853b60ee7c74e3a269ef58d002070%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
One way, though the slowest, is to find the template in the menu.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-5eb932c5757046c3b78825d2b746e13503b48758%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
You can also right-click and start typing the template's name or one of its search keywords and then hit Enter.
### With shortcuts
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-64573c4166ea153e079ab4a11df4437a60981de7%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
When you find a stock template in the right-click menu, you will see that most of them have a shortcut assigned to them. For example, for a video layer template, the shortcut is V.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-cba18d9fda5fbc5ded5f08fb5e9669738e719e1c%2FcreatingLayerWithShortcut1.gif?alt=media" alt=""><figcaption></figcaption></figure></div>
You can create a layer by simply holding this shortcut and clicking with a left mouse button (LMB). If you want to create a video layer the shortcut would be V+LMB.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-d4fdbb7e2f21863924d3ecf8b0b75e2c818c60f6%2FcreatingLayerWithShortcut2.gif?alt=media" alt=""><figcaption></figcaption></figure></div>
Another way is to hold Alt and hitting this key. If you want to create a video layer the shortcut would be Alt+V.
**Good to know**: the mouse needs to be in the Timeline editor window for this to work.
### By dragging and dropping
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-e0426ba0db1b63d529fb68a046847e35a8e5b153%2FcreatingAVideoLayerByDragging.gif?alt=media" alt=""><figcaption></figcaption></figure>
If you drag an asset of a specific type onto the Timeline, a menu will popup that will offer all the templates which have the asset type in its name.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-9c06d9d904404037a863b68f1fd53d88edbbdda0%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
For example, if you drag a video asset onto the Timeline you will get offered a popup menu with all the templates which have *Video* in them.
## Setting variables
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-52d36c6f7d293a6cf5ddbae25dd20f7d5fe3d02d%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
To set layer variables, you can of course use the controls in the Properties window. However, there are many drag-and-drop actions that will make your workflow faster.
### Drag & drop
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-b0ee0ff4ae4f680cc7f3e95adaf83fca7845c09a%2FassigningAssetToALayer.gif?alt=media" alt=""><figcaption></figcaption></figure>
For example, if you you drag any object or asset onto a layer, all variables with the correct type will get set with that object or asset. This means that if you drag a video asset onto a layer, all variables of video asset type will get set with that video asset.
**Good to know**: as a practical example, if you have a video layer and you want to assign a video asset to it, simply drag that video asset onto that layer.
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-33b04d91e26ccdb4c49f0030c8bb7d0e454393ee%2FassigningMappingToALayer.gif?alt=media" alt=""><figcaption></figcaption></figure>
Or if you drag a mapping, say, a video screen, onto a layer, all Mapping variables will get assigned to that mapping.
**Good to know**: as a practical example, if you have a video layer and you want to assign it to a particular mapping, simply drag that mapping onto that layer.
