> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/preparing-your-hardware-for-lightact/displayport-hdmi-converters.md).
# DisplayPort - HDMI converters
If it is required to convert DisplayPort outputs into HDMI outputs
If possible, we always recommend to use direct DisplayPort to DisplayPort connection between reActor and the displays.
We recommend to use direct DP-DP cable connection between the reActor and the displays.
If you need to convert DisplayPort to another format, such as HDMI, please note, not all converters are supported. Below you will find a list of the adapters we tested and are funtctional.
## A list of tested and functional DisplayPort to HDMI adapters
If you need to convert the output signal, please consider using the following adapters:
### StartTech DisplayPort to HDMI
You can find the link [here](https://www.startech.com/en-at/display-video-adapters/displayport-mini-displayport-adapters?filter_hostvidfilter=displayport\&filter_numofdispfilter=1\&filter_vidoutfilter=hdmi\&filter_cablengthfilter=adapter%2520%253C%25203ft%2520%252F%25201m\&filter_oscompatfilter=windows). We tested both DP2HDMI2 and DP2HDMI4KS.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-b7763b5299af3857d6008edaf63d1d65061114af%2Fdp2hd4ks.main.jpg?alt=media" alt="" width="188"><figcaption></figcaption></figure></div>
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-832406f174a0fd31378b7002ab0b7e5185293f68%2Fdp2hdmi2.main.jpg?alt=media" alt="" width="188"><figcaption></figcaption></figure></div>
