> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/quick-start/general-troubleshooting.md).
# General troubleshooting
There are several troubleshooting pages spread across these user docs related to specific features. On this page, however, you will find more general troubleshooting advice.
**Good to know:** please also have a look at the [system requirements](https://docs.lightact.com/preparing-your-hardware-for-lightact/getting-your-hardware-ready-to-run-lightact).
Project files shouldn't be saved in Google Drive or Dropbox folders or folders of similar services (see below).
<details>
<summary>LightAct's GUI is black upon launching</summary>
Most likely reason is that the GPU LightAct is running on is not a suitable one. Please make sure that you are using a discrete Nvidia GPU and that you've set up your laptop as per [this tutorial](https://youtu.be/siP-Rpj8S4E).
</details>
<details>
<summary>LightAct closes upon launch - cache</summary>
One possible step would be to go into *C:\ProgramData\LightAct\LightAct4* folder and delete these files and folders:
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-a682ff208d40c2b281b94de49f26ff4e86452b7c%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
If LightAct still doesn't launch correctly, try to:
1. uninstall LightAct completely, including the *Preferences*,
2. install it again.
In every case, please **contact us at <support@lightact.com>** and let us know what you find out.
</details>
<details>
<summary>LightAct closes upon launch - DirectShow</summary>
If LightAct closes upon launch and you are using either 4.12 or 4.13 version, please try launching LightAct with -omit "14" launch argument. This will prevent DirectShow module from loading.
You should therefore open CommandPrompt window:
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-0622a7533ccfb730792636c60e0877b71f34762a%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure>
and type in:
"C:\Program Files\LightAct\LightAct4\LightAct4.exe" -omit "14"
Please note, this command assumes that LightAct is installed in *"C:\Program Files\LightAct\LightAct4\\".* If you installed LightAct in a different location, you should modify the command accordingly.
Also, this means you will not be able to use DirectShow Receiver node in the Devices window.
</details>
<details>
<summary>LightAct 'keeps crashing' or acts weirdly</summary>
One reason for this might be that you have your project files in a Google Drive or Dropbox or a similar service. These programs interfere with file access which might cause LightAct to behave in a weird way.
</details>
