> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/layers-and-layouts/layer-connections.md).
# Layer Connections
Layer connections are a tool to share data and content between Layer variables in different layers. They present a more streamlined way to do that compared to [Global variables](https://docs.lightact.com/layers-and-layouts/layer-layouts/variables/global-variables.md).
In most cases you will be using Layer connections to pass textures from one layer to another, so let's demonstrate how this can be done.
## Example: Scroll texture
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-ba644848ae6122e9ab4e702b1e63db33d2eecfbf%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
Create a:
1. **Video screen** in the Viewport
2. **Color grid** layer and
3. above it a **Scroll texture** layer
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-fbb8cea797de5576e28069abdacd4afef25b798c%2FlayerConnectionCreatingWithDragging.gif?alt=media" alt=""><figcaption></figcaption></figure>
Then:
1. **drag** from the Video screen to Scroll texture layer.
2. **Alt + drag** from Color grid layer to Scroll texture layer
You've just created a layer connection. It copies the Texture variable from Color grid layer to Texture variable to Scroll texture.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-de442d532baa7e3814d424ebafdb3244753e0bb0%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
Now open **Layer connections** window. You can find it in the **Window** top menu. In this window you can see a Table with 2 columns:
* **Source**: with 3 sub-columns you set the *source variable*
* **Destination**: with 3 sub-columns you set the *destination variable*
**Good to know**: by Alt-dragging from one layer to another you create a layer connection between 2 layers that copies **all Texture** variables from the Source layer to all Texture variables of the Destination layer.
**Good to know**: to create layer connections of **non-texture** variables, you need to use Layer connections.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-057f4febd1d9b405764e35b0da6108ce26af3f21%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
If you want to temporarily disable a Layer connection just click on the eye icon in Layer connections window.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-4fca821854c6b165a47026eea09432aed0ecc39c%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
If you want to delete a Layer connection you can do that in Layer connection window or by right clicking on one of the layers and selecting **Delete layer connections**.
