> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/layers-and-layouts/cross-fade.md).
# Cross-fade
In LightAct, it is possible to achieve a cross-fade effect when jumping from part of the timeline to another. Similarly to Fade in and Fade out, cross-fade property can be adjusted on the Timeline, Section or Layer level.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-6f10c548da33101a91e643f017e416d6ec001851%2Fimage.png?alt=media" alt=""><figcaption><p>Cross-fade properties of a Timeline</p></figcaption></figure></div>
## **Cross-Fade for Timelines**
Cross-fade property of a Timeline determines cross-fade property of every section and layer in it, but only if their Cross-fade property is set to inherit.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-9d802b8f581a396341df2c9c0bc55a93ffedee73%2Fimage.png?alt=media" alt=""><figcaption><p>Cross-fade properties of a Section</p></figcaption></figure></div>
## **Cross-Fade for Sections/Layers**
Three options are available for setting cross-fade properties of sections or layers:
1. **Inherit**: Adopts the cross-fade behavior of a higher hierarchical object. If you set Inherit on a section, it is going to inherit the properties from a Timeline. If you set Inherit on a Layer, it's going to use the properties of the Section it is in.
2. **FadeDip**: this means that the outgoing layer is going to fade down while the incoming layer is fading up. This produces a slight dip in overall brightness/opacity
3. **FadeHold**: This means the origin layer is going to stay at the original opacity, while the destination layer is fading up over it. This results in unchanged overall brightness/opacity.
Please note, cross-fade does not work if you jump from one point to another on the same layer.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-984eb08a404b3af587ae7fffa25e5a0ecf9ec5e1%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
If you set Cross-fade to something other than Inherit, you'll be able to type in the Cross-fade time.
**Good to know:** if you are using cross-fade on a section, LightAct will always use cross-fade time of the destination section. Even if the cross-fade times of the origin section is different from the one of the destination section.
