> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/osc-and-midi/receiving-osc.md).
# Receiving OSC
## Receiving OSC
OSC receiver can receive different types of values (e.g. integer, float, string) on a specific OSC message address.
### Setup in the Devices window
Insert an **OSC Receiver** node and after you set *Stream* parameters check the **Receive** checkbox.​
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-ad231bfea23c32427c9fa200cf761a14a6ff37bf%2Fimage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
### Setup in the Layouts window
In the *Search* menu type **Read OSC** and choose the type of data you are receiving.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-ed56a042af4c8fe9571d36d3a79c344baaa990c1%2Fimage.png?alt=media&amp;token=843e1c9c-5b96-46bf-acc0-b4e32c40b857" alt=""><figcaption></figcaption></figure></div>
In the *Read OSC* node, choose the device in **Device** input, enter the OSC address In the **Address** string input and you are ready to receive data that is being sent to that address.
<div align="left"><figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-8fe81a19283fad63b8826a7cd82f0c6df3dd640b%2Fimage.png?alt=media&amp;token=d609e370-9843-4b77-a415-f6eafee551dc" alt=""><figcaption></figcaption></figure></div>
Since OSC protocol allows multiple values to be sent to the same OSC address, there is the **Index** input. This index is the index in the array of values that have been received in a bundle. We will explain how to send these bundle messages at the end of the next paragraph *Sending OSC.*
