Output Setup Overview
This chapter will explain how to setup how the content from your Viewport objects is pushed out of the server(s). The process is 2-step:
  1. Output Maps: in this step you will map the content from your Viewport objects onto Physical outputs on the servers you are using.
  2. Output management: in this step you will ensure that the framerates of all the physical outputs are correct and that all the outputs are synced and their EDIDs set up.
