LightAct 4.13
LightAct Changelogs are written by humans and polished by AI. Read more about how Changelogs are created here.
This changelog was created on 22 November 2025. It includes 10 Epics and 54 upgrades.
Robust Lightsync For 4.13
This epic focuses on making LightAct’s framelocking mechanism more streamlined and robust with better management of various states.
LA4-6137: Lightsync Unintentional Kicking Out Of The Session
Implemented mechanism to prevent machines from being prematurely disconnected from LightSync session.
Status: Testing
Flexible Asset Management For Big Shows
Improve asset management with enhanced manual refresh options and thumbnail generation, ensuring efficient performance and streamlined asset syncing across servers.
There are 4 new features in this epic.
LA4-6237: If There Is A Missing Asset, Layers Shouldn't Be Set To None.
Missing assets upon project file opening can lead to layers defaulting to 'None' in the dropdown, causing significant setbacks.
Status: Done | Requesters: KGR
LA4-6089: Non Blocking Asset Import
Added option to disable FileWatcher for user-controlled asset imports during shows. Asset imports now non-blocking with Swift notification and detailed logging.
Status: Done | Requesters: AKL
LA4-5943: Asset Import Changes
Asset ingestion is now divided into three non-blocking phases: import, get data (optional), and load & play. Some exceptions may apply.
LA4-6093: Drag From Thumbnail?
Enable drag-and-drop functionality from the entire asset row or at least from the thumbnail for video layer creation.
Status: Done | Requesters: SBA
LA4-5817: Asset Versioning For No Version In The Filename
If you have assets without version suffixes and assets with them, all of them will be listed in the Version dropdown. The one without the suffix will be listed as ‘No version’.
LA4-5414: Gui Improvement Of Assets Window
Remove two icons and mode column; streamline status display with asset icon colours and update tooltips for clearer communication.
Proxy Video Files & Notch Downscaled Playback
Introducing enhanced video playback capabilities: Proxy video file support allows Primary and Editor machines to play videos in lower resolutions, optimizing Viewport previews. Additionally, the Notch downscaled playback feature enables machines to downscale Notch rendering when full-scale resolution is unnecessary. Enjoy a streamlined and efficient preview experience.
LA4-5274: Proxy Video Files
Implement proxy video file support allowing users to provide lower resolution video files, identified by specific naming conventions (_proxy2 or _prx2 for 2x lower resolution, (_proxy4 or _prx4 for 4x lower resolution etc.).
LA4-6132: Downscaled Notch Playback
A new checkbox, 'Apply to Notch Blocks', has been added under Preview downsampling. When checked, it downscales the Play Notch Block node's resolution before rendering, then upscales it to the correct resolution, enhancing performance efficiency.
Easy-peasy Lightnet For 4.13
Enhance LightNet cluster management with easier and more versatile connection management and better performance indicators for all the machines in the cluster.
There are 7 new features in this epic.
LA4-5474: Performance Graphs For All Cluster Machines In Performance Window
Enable near real-time server performance data display in the Performance window when LightNet is active. Graphs should use Machine colour and display computer name labels. Add 'Status message frequency' dropdown in Preferences to adjust update intervals, ranging from 100ms to 1s for updates.
LA4-6187: Ability To End Lightsync From Non-primary Machines
Added an "End LightSync" button in the LightNet Management Sync column, allowing non-primary computers to stop a Primary from hosting a LightSync session.
LA4-6075: Turn Into A Secondary + Invite Into A Cluster By Dragging
Enables server drag action within the user's own cluster. Primary servers convert to Secondary and join the cluster, while Backup or Editor roles simply join. In the GUI, other clusters should not display a green icon; it remains white.
LA4-6073: You Should Be Able To Uncheck Device Checkboxes
Resolved an issue allowing users to uncheck checkboxes, crucial for effective "Transmit to others" functionality. Added a "None" option to prevent accidental selections. Now, users can manage nodes without enabling any checkboxes, ensuring smoother workflow and preventing unnecessary node creation.
LA4-5994: Force Vsync On All Outputs
Replaced the VSync checkbox with a "Vertical Sync" dropdown, offering two options: "VSync one output window" (default) and "VSync all output windows". Each setting is logged per output window. A basic tooltip provides clarity on the "Vertical Sync" settings.
LA4-5924: Minimize Gui Window Automatically
The GUI window will now automatically minimise to the taskbar when the output window is enabled on the same display as the GUI or any display on a secondary server. This enhancement aims to improve performance by potentially reducing the rendering load.
LA4-5476: Performance Top Right Indicator In Lightnet
The performance indicator on the primary server now reflects the status of the entire server group. If any server experiences a frame per second (FPS) drop from 60 to 30, the primary indicator will turn yellow, ensuring comprehensive performance monitoring.
Flexible Backup Lightnet Role
Enhanced backup functionality allows server selection for improved efficiency and faster switching, especially for large events.
There are 3 new features in this epic.
LA4-6065: Manual Backup Vs Automatic Backup Switch
Enable manual triggering of a Backup server to take over the role of another server within the same cluster by dragging the backup server onto the one that needs to be replaced. If the servers are not in the same cluster, or if the dragged server is not in a Backup role, no changes occur.
Status: Testing
LA4-6064: Backup Switch Should Happen Faster
When the Selective Backup feature is enabled, output windows on Backup servers mirror the settings of a primary server. Upon failure of a primary server, the backup verifies and synchronises output configurations to ensure a seamless switch within a single frame. If configurations differ, new output windows are established.
LA4-5187: Selective Backup & Automatic Functionality
Configure specific backup servers to manage designated servers, with an optional automatic failover feature. A "Setup" button allows assigning server responsibilities. By default, automatic failover is disabled, but enabling it reveals server assignment options. This feature is contingent upon a specific licence condition and is reflected in server roles.
Better Timeline Programming
Enhanced features ensure faster and more efficient timeline programming.
There are 6 new features in this epic.
LA4-6211: Snapping When Jumping On The Timeline With Left Mouse Button
The playhead will now snap to the nearest section beginning or end, marker, or layer boundary within the snap area on the timeline. If none are present, snapping will occur to the closest vertical line. This enhances precision when jumping across the timeline using the left mouse button.
Status: Done | Requesters: HIB
LA4-6208: Focus To Playhead
Implemented 'focus on playhead' action in additional cases. Now activated when pressing jump buttons: Additionally, if enabled, the focus action triggers when the playhead exits the right of the timeline editor, ensuring constant visibility.
LA4-5765: Ability To Delete Any Track
Remove the minus button for track deletion. Add a trash bin icon next to the track name or lock icon for improved functionality.
LA4-6203: Master Fade & Volume And Render Time Displayed In Timelines Window
Displayed within the Timelines window are now the Timeline fade and Timeline master volume. Extended tooltips align with those in the Timeline Editor. Additionally, master volume and render time features have been introduced, addressing user feedback for enhanced functionality.
LA4-6161: Playback Speed Multiplier For Timeline
Playback speed adjustment for timelines is now possible, provided the timeline is not synchronised. This feature was requested during training.
LA4-6069: Select All To Left/right On The Same Track
Added commands to select all layers on the current track: right, left, or all directions.
LA4-6206: Non-whole Project Framerates Don't Work
Resolved an issue where setting Project Settings to non-standard frame rates (e.g., 29.97, 59.94, 48) caused misalignment between the timeline display and playhead time. This also affected single-frame scrolling functionality. Non-whole project frame rates have been temporarily removed but will be reinstated once the issue is fully addressed.
Status: Code Review | Requesters: HIB
LA4-6331: Pasting Layers If There's Not Enough Space
Enhanced layer-pasting functionality now verifies available space and unlocked track status before pasting. If either condition fails, it automatically seeks the next available track. If no suitable track exists, it creates new tracks to accommodate the pasted layers, ensuring seamless integration with their original durations.
LA4-5692: Duplicate Timeline Should Also Be In Properties Menu Of Timeline Editor Window.
Add 'Duplicate Timeline' option to the Properties menu in the Timeline editor for enhanced accessibility.
Qol September 25
Various Quality of Life improvements done in September 2025.
There are 10 new improvements in this epic.
LA4-5084: Integer As Dropdown_remap Value
When setting Appearance Integer as a dropdown, the Remap value is now hidden and disabled.
LA4-6186: Non-latin Characters In Project Names
Support for non-Latin characters in project file names is temporarily removed due to crash issues. Invalid characters will trigger a warning.
LA4-6179: Dragging From Variable Group
Fixed unnecessary Getter/Setter menu appearance when dragging from variable groups.
LA4-6172: Timecode Monitor Window Should Show All Tc Sources.
Redesigned timecode monitor to always display all TC sources, allowing name editing and offsets. Displays "No MIDI Receiver" when no sources are present.
LA4-6152: Multiple Incoming Art-net Tc
Support added for multiple incoming Art-Net TC sources, enhancing flexibility and integration capabilities.
LA4-5879: Incorrect Number Of Core Count In Some Cases
Incorrect CPU core count for Intel Xeon Gold 5512U; should be 28 cores, 56 threads.
LA4-5680: Projectors Should Not Appear In Mapping Dropdowns
Remove Projector from Mapping dropdown as it no longer supports Canvas (legacy), now hidden under -legacy launch argument. Affects approximately 0.5% of projects.
LA4-5446: Hide Viewport Warnings So That The Client Doesn't See Them
Option to hide all viewport warnings.
Status: Done | Requesters: MFR
LA4-3811: Better Logs
Added logs for enabling OSC Receiver with missing, empty, or incorrectly logged file paths.
LA4-5652: Framecount Should Be Visible In Asset's Properties
Feature inquiry regarding calculating numbers using time and FPS. Clarification on task difficulty requested, with a suggestion to defer if low priority.
Status: Done | Requesters: MVI
Qol October 25
Quality of Life enhancements planned for October 2025.
LA4-6070: Restore To Default
Added "Restore to default" command for unconnected inputs in variable groups.
Node Upgrades For 4.13
New and upgraded nodes added in LightAct 4.13.
LA4-5767: On Shutdown Node
Introducing "Run on Shutdown", a simple node that triggers once when LightAct closes. Keywords: close, exit.
LA4-5580: Absolute Value
Introducing a node that outputs absolute values for Int, Float, and other types, ensuring all components receive absolute values.
Status: Done | Requesters: SUP
LA4-6171: Vignette Function
Introducing 'Texture Vignette' node with intuitive controls, enabling enhanced texture manipulation without overhauling existing code.
LA4-5795: Ability To Output Softedge Handles
Enable Softedge lines for Output during setup. Update "Draw handles" checkbox to "Render handles" for consistency with Warp nodes.
LA4-5706: Nodes For Json Packing And Parsing
Feature request received for JSON Parser and Packager nodes in LA4, based on previous implementation in LA3.
LA4-5634: Expression Node
Introducing an Expression Node with default float inputs, allowing users to create custom equations and add inputs dynamically for enhanced flexibility.
There are 4 new improvements in this epic.
LA4-6216: Scale X In Scale Y In Render Texture
Introduce separate Scale X and Scale Y inputs for better dimension control, ensuring compatibility with previous versions.
LA4-5802: Project Framerate Info In Nodes
Integrate Project framerate information into nodes by adding an output pin to the Application Tick node or creating a new Project framerate node.
LA4-5238: Content Override Boolean
Add a "Content override" boolean option to some Get data nodes telling you if an object has Content override enabled or not.
LA4-5135: Panning Of Node Windows
Improved window panning behaviour: Node dragging now initiates immediate panning, with speed increasing as cursor approaches window edge.
Curve Editor Upgrade 25
Enhanced Curve editor for faster, easier multi-curve workflows and keyframe management.
LA4-5229: Double Click Create A Point
Double-clicking in the curve editor creates points directly at the click location for single-component curves and on existing curves for multi-component curves.
There are 4 new upgrades in this epic.
LA4-6434: Pixel Straddling Option In Dmx Fixtures
The pixel straddling property determines whether a single DMX pixel can span across universe border. The checkbox is part of the Fixture editor under Pixel properties, and is enabled by default.
LA4-6404: Mosys & Freed Receiver Cause Crash
Resolved crashes when creating MoSys and FreeD Receivers in new projects.
LA4-6309: Adjustable Max Pixel Number In Dmx Fixtures
Max number of pixels in a DMX fixture has been increased to 1024.
LA4-6268: Deltacast Sender With Sdi Card Not Working
Resolved an issue where the Deltacast Sender node failed to initialise with the DELTA-12G-e-h 4i2c card.
