The URL `understanding-the-basics/working-quickly-in-lightact/keyboard-shortcuts` does not exist. This page may have been moved, renamed, or deleted.
- [Shortcuts](https://docs.lightact.com/quick-start/shortcuts.md)
- [Deltacast Setup](https://docs.lightact.com/integrations/content-io/deltacast-setup.md)
- [Testing your computer](https://docs.lightact.com/preparing-your-hardware-for-lightact/testing-your-computer.md)
- [Texture Sharing](https://docs.lightact.com/real-time-content-playback/unreal-engine-integration-overview/texture-sharing.md)
- [Layer Layouts](https://docs.lightact.com/layers-and-layouts/layer-layouts.md)
GET https://docs.lightact.com/quick-start/shortcuts.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/quick-start/shortcuts.md`).
