The URL `release-changelogs/lightact-4.15.1` does not exist. This page may have been moved, renamed, or deleted.
- [LightAct 4.15](https://docs.lightact.com/release-changelogs/lightact-4.15.md)
- [LightAct 4.16](https://docs.lightact.com/release-changelogs/lightact-4.16.md)
- [LightAct 4.14](https://docs.lightact.com/release-changelogs/lightact-4.14.md)
- [LightAct 4.13](https://docs.lightact.com/release-changelogs/lightact-4.13.md)
- [LightAct 4.15.1](https://docs.lightact.com/release-changelogs/lightact-4.15/lightact-4.15.1.md)
GET https://docs.lightact.com/release-changelogs/lightact-4.15.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/release-changelogs/lightact-4.15.md`).
