LightAct 4.13 Beta 2
LightAct Changelogs are written by humans and polished by AI. Read more about how Changelogs are created here.
This changelog was created on 15 December 2025. It includes 4 Epics and 9 upgrades.
Robust Lightsync For 4.13
This epic focuses on making LightAct’s framelocking mechanism more streamlined and robust with better management of various states.
LA4-6137: Lightsync Unintentional Kicking Out Of The Session
Implemented mechanism to prevent machines from being prematurely disconnected from LightSync session.
Status: Testing
Qol December 25
LA4-6507: Play Mode Timecode Skipping
Using 30 fps MTC with a 60 fps timeline in Timecode play mode causes frames 30–59 to be skipped, jumping from 29 to 1 each second. Expected: seamless 60 fps playback that correctly maps 30 fps timecode without frame loss.
Status: Code Review | Requesters: SUP
LA4-6496: Undo Stack
Add an Undo Stack menu beneath Redo. Selecting it opens a compact viewer, similar to the Console window, that displays the current machine’s undo history with timestamps and concise command details.
LA4-6476: Better Watches For Integers That Appear As Dropdowns
Fixed Watch display for integer output pins rendered as dropdowns. It now shows the selected label with its integer value, e.g., “test [0]” instead of just “test,” improving clarity.
Mapping Improvements For 4.13
Enhanced CanvasMaps and OutputMaps windows for improved speed and convenience during large-scale events.
LA4-6223: Absolute Mappings Instead Of Relative
Improved Subarea mapping reliability by switching coordinates from floats to integers. This prevents off-by-one rendering errors (like a missing 1px on the right edge) when mapping images to Canvas—for example, a 1000x600 PNG with 200x200 tiles. Coordinates are now stored and rendered with exact pixel alignment.
Status: Done | Requesters: SUP
Crossfade Upgrades For 4.13
Enhanced crossfade functionalities and workflows for timeline programming.
LA4-3781: Crossfade Property To Section
Sections now include Crossfade settings via a dropdown with Inherit or Fade. Choose Fade to set Crossfade time (s); choose Inherit to use Timeline properties. Crossfade time is always taken from the destination (section or layer) only—never combined.
LA4-6343: Timeline Crossfade Property
Added a Cross-fade time [s] property to the Timeline, mirroring the option in Layers. Define transition duration in seconds for smoother crossfades and consistent control across timeline items.
LA4-6342: Layer Fade Properties And Crossfade Upgrade
Layer’s cross-fade dropdown has 2 options: Inherit, which means the Layer’s crossfade is inherited from the section’s properties and Fade where the user has an option to manually set the crossfade property of that layer.
There are 1 new upgrades in this epic.
LA4-6508: Play And Pause Doesn't Progress Across The Section Even After Pressing Space
Fixed an issue where pressing Space at the end of a section did not consistently advance playback to the next section. The playhead paused at the boundary and only sometimes progressed after multiple key presses, even after resizing sections. Playback now reliably continues into the next section on a single Space press.
