LightAct 4.13 Beta 1
Robust Lightsync For 4.13
LA4-6137: Lightsync Unintentional Kicking Out Of The Session
Flexible Asset Management For Big Shows
LA4-6237: If There Is A Missing Asset, Layers Shouldn't Be Set To None.
LA4-6089: Non Blocking Asset Import
LA4-5943: Asset Import Changes
LA4-6093: Drag From Thumbnail?
LA4-5817: Asset Versioning For No Version In The Filename
LA4-5414: Gui Improvement Of Assets Window
Proxy Video Files & Notch Downscaled Playback
LA4-5274: Proxy Video Files
LA4-6132: Downscaled Notch Playback
Easy-peasy Lightnet For 4.13
LA4-5474: Performance Graphs For All Cluster Machines In Performance Window
LA4-6187: Ability To End Lightsync From Non-primary Machines
LA4-6075: Turn Into A Secondary + Invite Into A Cluster By Dragging
LA4-6073: You Should Be Able To Uncheck Device Checkboxes
LA4-5994: Force Vsync On All Outputs
LA4-5924: Minimize Gui Window Automatically
LA4-5476: Performance Top Right Indicator In Lightnet
Flexible Backup Lightnet Role
LA4-6065: Manual Backup Vs Automatic Backup Switch
LA4-6064: Backup Switch Should Happen Faster
LA4-5187: Selective Backup & Automatic Functionality
Better Timeline Programming
LA4-6308: Splitting Layers
LA4-6211: Snapping When Jumping On The Timeline With Left Mouse Button
LA4-6208: Focus To Playhead
LA4-6205: Proper Locking Of Tracks
LA4-6204: Alert With Overlapping Custom Tc Times
LA4-5765: Ability To Delete Any Track
LA4-6214: All But Excluded Section
LA4-6203: Master Fade & Volume And Render Time Displayed In Timelines Window
LA4-6161: Playback Speed Multiplier For Timeline
LA4-6069: Select All To Left/right On The Same Track
LA4-5768: Assign A Mapping/asset To All Layers In A Timeline/track
LA4-6206: Non-whole Project Framerates Don't Work
LA4-6340: Show Play Times
LA4-6331: Pasting Layers If There's Not Enough Space
LA4-5692: Duplicate Timeline Should Also Be In Properties Menu Of Timeline Editor Window.
Qol September 25
LA4-5084: Integer As Dropdown_remap Value
LA4-6186: Non-latin Characters In Project Names
LA4-6179: Dragging From Variable Group
LA4-6172: Timecode Monitor Window Should Show All Tc Sources.
LA4-6152: Multiple Incoming Art-net Tc
LA4-5879: Incorrect Number Of Core Count In Some Cases
LA4-5680: Projectors Should Not Appear In Mapping Dropdowns
LA4-5446: Hide Viewport Warnings So That The Client Doesn't See Them
LA4-3811: Better Logs
LA4-5652: Framecount Should Be Visible In Asset's Properties
Qol October 25
LA4-6070: Restore To Default
Node Upgrades For 4.13
LA4-5767: On Shutdown Node
LA4-5580: Absolute Value
LA4-6171: Vignette Function
LA4-5795: Ability To Output Softedge Handles
LA4-5706: Nodes For Json Packing And Parsing
LA4-5634: Expression Node
LA4-6481: A Node That Toggles Sending Of Dmx
LA4-6216: Scale X In Scale Y In Render Texture
LA4-5802: Project Framerate Info In Nodes
LA4-5238: Content Override Boolean
LA4-5135: Panning Of Node Windows
Curve Editor Upgrade 25
LA4-5229: Double Click Create A Point
LA4-6482: A Node That Toggles Sending Of Dmx - For 4.12
LA4-6434: Pixel Straddling Option In Dmx Fixtures
LA4-6404: Mosys & Freed Receiver Cause Crash
LA4-6309: Adjustable Max Pixel Number In Dmx Fixtures
LA4-6268: Deltacast Sender With Sdi Card Not Working
