LightAct 4.13.1
This changelog was created on 01 February 2026. It includes 1 Epics and 3 upgrades.
Qol January 26
LA4-6620: Deltacast Interlaced Signal Handling
FHD60i video sent via FLEX HMI-10 and GWY316-4 displayed as a halved texture in LA due to improper interlaced field handling. Enable Field Merging to resolve. Set stream property VHD_CORE_SP_FIELD_MERGE to TRUE, as recommended by Deltacast.
There are 2 new upgrades in this epic.
LA4-6623: Hide Bugsplat With A Launch Argument
Added a launch argument to control BugSplat behavior in sensitive scenarios. When -no_bugsplat is present (via command line or options.ini), the app will either fully disable BugSplat or suppress only the BugSplat popup while still writing crash dumps to the crashDumps folder. Behavior depends on BugSplat SDK capabilities. This provides a cleaner user experience without losing critical crash diagnostics where supported.
LA4-6441: Mute All Autoblend Nodes
Resolved an issue where enabling “Mute all AutoBlend nodes” showed a warning but still output a masked texture from AutoBlend to Texture Blend. The mute action now correctly bypasses the blend mask, passing through unblended textures as expected.
Status: Done | Requesters: RIG
