LightAct 4.13 RC1
LightAct Changelogs are written by humans and polished by AI. Read more about how Changelogs are created here.
This changelog was created on 30 December 2025. It includes 1 Epics and 16 upgrades.
Easier Support Framework
There are 1 new features in this epic.
LA4-6470: Package For Support
Reintroduced “Package for Support” to streamline sending project files to LightAct Support.
There are 14 new improvements in this epic.
LA4-6497: Sub-second Precision Of Log Entries
Log timestamps now include millisecond precision to improve event ordering and diagnostics as log volume grows. Example format: [YYYY-MM-DD HH:MM:SS.mmm], e.g., [2025-11-27 10:22:31.231].
LA4-6495: Better Logging Of Cue Triggers
Every cue fired manually, via OSC, or DMX now logs its trigger with cue name, timeline, and source.
LA4-6494: Ability To Omit Loading Of Devices
Added an option to skip loading selected devices during LightAct launch, enabling faster startup and easier troubleshooting by isolating problematic hardware.
LA4-6493: Better Logging Of Devices
Added granular device initialization logs. The system now records per-device load messages (e.g., “Loading NIC… NIC loaded”, “Loading Blackmagic… Blackmagic loaded”). This improves visibility and troubleshooting, especially when specific devices are intentionally omitted from loading.
LA4-6492: Better Section And Layer State Logging
Added logging for section and layer state transitions. When the playhead enters or leaves them, the log records: “Layer X entered active/inactive state” and “Section Y entered active/inactive state,” improving traceability and debugging.
LA4-6491: Better Timeline State Logging
Improved timeline diagnostics with expanded logging. The system now records all play state changes; end-of-section events in Play-to-End with resulting pause or loop actions; and playhead jumps. Timeline and group sync activity is tracked, including Engaged/Disengaged changes triggered via DMX, OSC, or manual control. Timecode state transitions are logged, and when entering Chasing TC the current TC is included. This replaces the previous “enters synced state” log entry.
LA4-6478: Better Tcp/udp/osc Logging
Added a "Log every message" checkbox (default on) to all six nodes. When enabled, every incoming message is recorded to Logs with source IP and port for easier tracing. Example entries: "UDP Receiver 0" received message "testMessage" from 192.168.0.11 on port 6343; "OSC Receiver 0" received message "oscMessage" from 192.168.0.15 on port 6345.
LA4-6477: Better Play Video Layer Logging
Added structured, rate-limited logging for the Play video node. Captures key lifecycle events: phase transitions (Loading, Ready, Scrolling), buffer operations (start/filled for “always ready” and “play” buffers), and audio enable/disable actions. Logs include layer context (e.g., “my test layer”) for clear traceability. Repeated events are deduplicated and throttled to avoid spam, providing visibility into asset changes and playback state without overwhelming log files.
LA4-6435: Bugsplat Should Be Dumped To Project Folder
BugSplat now saves crash reports to a custom crashDumps directory located next to the .la file, improving organization and making logs easier to find and manage.
LA4-6318: Autosaves Should Be Saved In Project Folder
Autosave files are now stored in an Autosaves folder within the project folder, alongside the .la file. Autosave behavior is unchanged. On normal exit, autosave files are deleted—even when exiting without saving—to prevent leftover recovery files.
LA4-6317: Edids Should Be Saved In Project Folder
EDID-related files are now saved in the project folder alongside the .la file instead of ProgramData. This improves portability, simplifies backups and version control, and reduces permission issues; existing projects remain compatible.
Status: Testing
LA4-6316: Saves Should Be Saved In Project Folder
All generated saves are now written to Projectfolder\Exports, located next to the .la file, instead of ProgramData\Lightact\Lightact4\saves. This change keeps exports with their projects for easier versioning, backup, and distribution.
LA4-6315: Console.log
Introduced console.log in the Logs folder for high-volume diagnostics that would clutter the main Log file and Logs window. The file is overwritten each session and begins with "###LightAct 4 Console File###", followed by "#Build:" and "#Current time:" metadata. This is an initial setup; additional content categories may be defined later.
Status: Code Review
LA4-6314: Logs Should Be Saved In Project Folder
Log files and videoimportsummary.json now save to a Logs folder alongside the project file, ensuring consistent organization and easier access.
There are 1 new upgrades in this epic.
LA4-6513: Ignoring Tc
Added an intermediate state to Timeline: Engaged (Ignore TC). When the Timeline is engaged and chasing timecode, any manual trigger—pause, jump buttons, or cue triggers from the Cue List via UI, OSC, or DMX—no longer disengages it. Instead, the Timeline enters Ignore TC, allowing manual control without losing engagement. The Timeline automatically re-engages and resumes chasing when the incoming timecode jumps or stops and starts again.
Status: Done | Requesters: SBA
