> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/real-time-content-playback/unreal-engine-integration-overview/unreal-engine-integration-troubleshooting.md). Agents can also search and read this documentation through its [MCP server](https://docs.lightact.com/~gitbook/mcp).
# Unreal Engine Integration Troubleshooting
Below we list some common problems and issues.
<details>
<summary>I cannot get the texture sharing to work.</summary>
In most cases this is due to some Unreal Engine plugins being misconfigured. Please follow [this troubleshooting guide](https://docs.lightact.com/real-time-content-playback/unreal-engine-integration-overview/unreal-engine-integration-troubleshooting/texture-sharing-troubleshooting.md). It will help pinpoint the cause of the issues.
</details>
<details>
<summary>Texture is available, but it's wrong</summary>
The causes could include:
* Thrower2UCam and Projector2UCam workflow relies on Unreal cameras being a perfect match to LightAct's throwers or projectors. It has been observed that **Player start** actor can mess up nDisplay viewports, because it moves the entire nDisplay configuration.
</details>
<details>
<summary>nDisplay instance isn't launched or it crashes instantly</summary>
* Avoid all spaces in filepaths,especially the path to your nDisplay configuration file.
* Check that you have nDisplay plugin enabled.
* Check that you are using the correct version of Unreal Engine and LightAct plugin. Also check that you've enabled all required plugins.
* Try launching your cluster with Unreal's Switchboard application and see if it works there. You can find out detailed instructions on Unreal Engine's documentation.
</details>
