> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/real-time-content-playback/unreal-engine-integration-overview/required-unreal-engine-plugins.md). Agents can also search and read this documentation through its [MCP server](https://docs.lightact.com/~gitbook/mcp).
# Required Unreal Engine Plugins
Please note, Unreal Engine integration has changed significantly for Unreal Engine 5.3 and 5.4, so this User Doc is outdated.
In order for the integration to work there are a few required plugins:
## LightAct Unreal Engine Plugin
![](https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-dfb6de500f2c4fb6e6f3d0654f19592bcdcf0bca%2Fimage.png?alt=media\&token=948e4f09-3a6b-435d-b073-f353d531e2c4)
LightAct's Unreal Engine Plugin takes care of the data flow between LightAct and Unreal.
As such, it is a crucial component of the entire Integration.
Please make sure to use the version of the plugin that matches the version of your Unreal Engine project.
## Unreal Engine Plugins
Integration with LightAct requires some additional plugins that are provided by Epic Games. The easiest way to enable all of them in one go is to create Unreal Engine project based on nDisplay template. Hovewer, if you want to do it manually, these are the plugins that are required:
### Texture Share
<div align="left"><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-80030cacb5ed34432417d81b0fad8c1a7367cd28%2Fimage.png?alt=media&amp;token=d0eb253a-0742-4f1c-a9de-faef2ed55943" alt=""></div>
Texture Share plugin enables texture sharing of Unreal Engine textures.
### nDisplay
![](https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-f9cb17f5e8220babd6a77bf46a6b52aec12ed544%2Fimage.png?alt=media\&token=afe500b7-0112-43b3-b066-fdfe42ca82e9)
nDisplay enables nDisplay related functionalities.
### Other
There might be other Unreal Engine plugins you'll want to enable in your project. Please refer to Unreal Engine documentation for more information.
