Troubleshooting LightSync
This guide provides a structured approach to troubleshooting sync issues between multiple servers in a LightSync session.
Common symptoms
Outputs are visibly out of sync
Texture motion is not smooth
Performance graphs contain large periodic spikes
Synchronization is unstable or inconsistent
Before You Start
LightSync synchronizes all participating servers. If one server is unable to maintain stable frame timing, synchronization issues may occur across the entire system.
Before troubleshooting LightSync, verify that each server is operating correctly and reduce the setup to the simplest possible configuration.
Simplify the setup
Hardware configuration
One GUI display (per server)
One Output display (per server)
Synchronize output display using either Genlock or Framelock
GUI display should not be synced
If Primary doesn't have an output display, Framelocking or Genlocking is not required
All displays use the same refresh rate
The project framerate matches the display refresh rate
Direct connection (if possible)
Network configuration
Dedicated switch and network
Only LightAct machines are connected
No unnecessary network traffic
Close unnecessary applications
Remote Desktop sessions such as VNC Viewer, TeamViewer, AnyDesk,...
Web browsers
GPU monitoring tools
NVIDIA Control Panel
Other unnecessary applications running in the background.
Verify Stable Synchronization
A single server occasionally missing a frame can affect synchronization across the entire system.
Establish cluster
In Output Maps window Enable output displays and set Content override to Strobe
Begin LightSync session
Observe common symptoms
Healthy behavior
Graphs are generally stable
Small fluctuations are acceptable
Outputs appear visually synchronized
Problematic behavior
Large spikes appear regularly
One machine behaves significantly differently from the others
Outputs visibly drift or stutter
If synchronization is stable in the simplified setup, gradually reconnect the remaining equipment until the issue reappears.
Collect diagnostics
If synchronization issues persist, collect and send the following information to support@lightact.com.
Output Recording
In Output Maps, enable the diagnostic Render overlay and record a video of all output displays.
The information of the Render overlay should be visible on the recorded video.
NVIDIA Information
Provide a screenshot of NVIDIA Control Panel → View System Topology
This contains important information about
GPU model
Driver version
Synchronization configuration
Package for support
Please follow these instructions
