Set up Mosaic
Go to NVIDIA Control Panel and under Workstation, select Set up Mosaic. On the top left choose Create new configuration.
Under Sync capability, an icon indicates whether the GPUs in your system are able to synchronize multiple displays with each other. If you are not using Mosaic with sync-capable GPUs, it is recommended that you enable V-Sync.
You can do so in the 3D Settings section, under Manage 3D Settings. In the Global Settings tab make sure the Global presets are set to Base profile. In the Settings area, look for Vertical sync. Once you turn it On, click Apply.
NVIDIA Mosaic Set up Window will appear. In the Select topology section, you choose the Number of displays, Topology, Orientation of displays and Configuration name. When you have everything set up as wanted, click Next.
In the Select displays section you can choose which of the connected displays you would like to include in the Mosaic. You can also choose the desired Refresh rate and Resolution per display. Under Total resolution, you can see the number of total horizontal and vertical pixels.
In the Arrange displays section you will have the option to place your displays in a desired order. It might be a good idea to take a note of this setup as it might come in handy when you start mapping your content in LightAct. When you are done, click on the Apply button.
Once the changes have been applied, you need to tell your machine to keep them. An Apply Changes pop up window will appear where you will have around 20 seconds to confirm your choices. Select Yes.
To finish up the process you can either click on Finish button on the bottom right corner or you can continue to the Adjust overlap and bezel correction. In this section, you have the option to adjust the horizontal and vertical edge gaps as needed. If you have sync-capable GPUs, you can also overlap edges.
