> For the complete documentation index, see [llms.txt](https://docs.lightact.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.lightact.com/output-setup/output-management/modify-or-disable-mosaic.md).
# Modify or Disable Mosaic
To modify or disable Mosaic, go to the **Set Up Mosaic** section under *Workstation* in the *NVIDIA Control Panel.*
## Modify Mosaic
In the *Set Up Mosaic* page, locate the Mosaic you would like to adjust and select **Modify** button.
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-7b75d0dba9b712a56561d7ce694ec5970eb58816%2FModify.png?alt=media" alt=""><figcaption></figcaption></figure>
This will open the *NVIDIA Mosaic set up* window which is explained step-by-step in the [Set up Mosaic](https://docs.lightact.com/output-setup/output-management/set-up-mosaic.md) page.
## Disable Mosaic
Similarly, to disable a Mosaic, you first need to pinpoint it in the *Set Up Mosaic* page. Then, click on **Disable** button.
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-77be653b19fdf46206f760164fa80783501d3d6e%2FDisable.png?alt=media" alt=""><figcaption></figcaption></figure>
To confirm this action, click **Disable** again on the additional pop up window.
<figure><img src="https://3312042618-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F9sVaJpWJhPbmscipukhh%2Fuploads%2Fgit-blob-2b0ecadcc62b20e6709ecd374073f0c99e4a2464%2FDisableMosaic.png?alt=media" alt=""><figcaption></figcaption></figure>
