The URL `dmx/dmx-in/using-single-channel-value-in-layouts` does not exist. This page may have been moved, renamed, or deleted.
- [Get DMX in Layer Layouts](https://docs.lightact.com/dmx/dmx-in/get-dmx-in-layer-layouts.md)
- [Set DMX in Layer Layouts](https://docs.lightact.com/dmx/dmx-out/set-dmx-in-layer-layouts.md)
- [Index manager](https://docs.lightact.com/dmx/dmx-in/index-manager.md)
- [Controlling Timelines with DMX](https://docs.lightact.com/dmx/dmx-in/controlling-timelines-with-dmx.md)
- [Controlling Layers with DMX](https://docs.lightact.com/dmx/dmx-in/adjust-layer-variables-with-dmx.md)
GET https://docs.lightact.com/dmx/dmx-in/get-dmx-in-layer-layouts.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/dmx/dmx-in/get-dmx-in-layer-layouts.md`).
